OK back at home now.
Trying the 160Gb I get this:
It sits at that for ages, then I get this:
Then I hook up PuTTy and power cycle the empeg and I get this:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30103019) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffc2
ide_data_test: wrote 0xffff read 0xffc2
ide_data_test: wrote 0xaaaa read 0xaa82
ide_data_test: wrote 0x5555 read 0x57c0
ide_data_test: wrote 0x0000 read 0xff42
ide_data_test: wrote 0xffff read 0xff42
ide_data_test: wrote 0xaaaa read 0xaa02
ide_data_test: wrote 0x5555 read 0x5740
ide_data_test: wrote 0x5555 read 0xff42
ide_data_test: wrote 0x0000 read 0xff40
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:cb
empeg-pump v0.03 (19980601)
Press Ctrl-A
So no dice then.
With the 120Gb and just the power cycle, I first get this:
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xff00
ide_data_test: wrote 0xffff read 0xff00
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9120822A, ATA DISK drive
ide_data_test: wrote 0x0000 read 0xffa5
ide_data_test: wrote 0xffff read 0xffa5
ide_data_test: wrote 0xaaaa read 0xaaa5
ide_data_test: wrote 0x5555 read 0x55a5
Then this after a very check power cycle (hard power hardly removed):
ide_data_test: wrote 0x5555 read 0xffa5
Now, for the empeg this is possibly a shot in the dark on my part, but it tallies with some of the problems I mentioned earlier with newer hard drives requiring much longer spin up times.
The second attempt at detecting the 120Gb seems to have found it much faster.
I assume that is what the above info refers to ?
I can get the 160Gb to appear in the serial output in the same manner, quickly recycling the power to the empeg.
So, is it possible to have some sort of wait cycle placed into the kernel before an attempt is made to detect the hard drive?
This is what I've had to do at work to make hard drives work correctly.
e.g. Spin up till drive ready times are running at 16 seconds !!! on newer Seagate SV35.4 drives.
P.S: 120Gb installs ok, but really want to use the 160Gb :o)
Is there a reset header on the PCB which I can trip to reset the empeg without having to lose the power? I wondered about tripping the 3.3V jumpers but that doesn't sound like a hugely fantastic idea.
That way I can keep drive power but restart the kernel over.
