So the way this works is you start Emplode and select a connection. There is now a new File Menu entry called "Open Clone..." that will open a second Emplode window. You can then select a second connection. The two Emplodes share a common clipboard, so you can copy and paste playlists and tunes across the two devices and sync them. The syncing will actually be direct Empeg-to-Empeg (i.e. it will read the Tune off the first Empeg and write it straight onto the second Empeg). Kind of cool :) It uses serial no's + FID's to create a new tag that is a Global FID. This is used to maintain reference counting across multiple Empegs. What that means is that multiple people can share tunes and they will all be reference counted properly among the group. The only thing that isn't tracked right now is if someone actually _modifies_ a reference counted playlist (i.e. the other people will think they have the playlist and won't get that new tune) -- however, you can copy and paste just the new tune into the reference counted playlist. Things are cleaned up a bit too so each Emplode window operates independently, so you can actually copy and paste both directions and then sync each Empeg seperately. Hopefully my second empeg will arrive tomrrow so I can test this out more thoroughly (in the meantime, I'm syncing _very slowly_ to a friend's across the Internet, which is really slick, I might add).
Mike
