You could also pull the drive and mount it as an extra on another machine, then poke through the files as you like.
You won't be able to run any of the software he had, though.
Ah! Now,
that I can do. My Vantec external dock will read 3.5 or 2.5 disks (I don't know if the computer is a laptop). Chances are the files she wants to read will be common, .xls or .doc and I'll be able to read them.
Edit: Nice idea while it lasted. My external dock is for SATA drives, and the computer is an ancient Dell with two 80-GB IDE drives. I guess I better try the admin password cracker stuff... which will be a neat trick because my CD burner will no longer burn CDs, only DVDs, and this computer has only a gigantic (6" x 8") CD player/burner.
db
