Description: When the hard disk in the empeg is not found, the sad tux is displayed with the message "no hard disk found, contact support". If I turn of the ignition, the empeg remains powered on in this state.
Expected result: Upon turning off the ignition, the empeg should turn off immediately. It cannot honour the timeout setting in config.ini, since it's on a (now dead) disk.
Actual result: the empeg remains powered on at the error screen.
frown and wink
