In reply to:
Startup can peak at just under 1A. Normal running is about 500mA IIRC (might be 600?). Standby is ~250mA (display off) and sleep is <5mA.
Hugo, thanks for the response. When I turn the ignition off, the unit goes into standby for x number of minutes - based on the value set in emplode right (light flashing - starts right back up again in seconds)? Is it accessable through the network at this point? When does it go to sleep? It seems to me that after that timer expires I get a whole new boot when I turn the ignition on again.
I assume that wake-up through the LAN wouldn't work in sleep mode?
=-C
______________________________________
Queue 351, Now Mk II #60000022 18gb, Blue
______________________________________ Queue 351, Mk I, 30GB Mk II #60000022 80gb, Blue - docked Mk2a, 80GB, Bruface, lighted buttons and dial
