Presumably, you're planning on hiding the sockets behind the TV?
Yes
Is the TV going to be fitted flat on (or into) the wall, or on a mount? If you use a wall mount, they're usually adjustable for pitch, which gives you some freedom with regard to height.
Flat onto the wall. I didn't realise brackets allowed height adjustment. OK will order a bracket and see what it does. Thanks
