Correction...I let the test run its course, and sometime between my last post and now it finally completed with the following message in GSmartControl, which I used because the command line test doesn't even let you know when it's truly done, it just works in the background:
Test result: Completed with read failure.
Check the Self-test Log for more information.
I have attached that log.
TOSHIBA_MK1646GSX_Z7BGT09HT_2012-06-10.txt (178 downloads)
