Originally Posted By: dbrashear
odds that i can do work as fine as required to salvage such: low.
another thought, tho: is there anything which is likely to be available that would be compatible either directly or with a PIC between it and the empeg's display board, to replace the noritak VFD with?
Hmm. With kernel mods, maybe you could hook up an LCD, but suitable LCDs aren't exactly thick on the ground either frown
