I fixed a setting save bug... Check the exit command box has what you expect in it... (Sometimes it would go blank, and then would use the default of a single q)
When the player exit routine is called, It pauses for a half a second between each line, so you can always add more q's if that seems to be the problem.
Jazz
(List 112, Mk2 12 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
Jazz
(List 112, Mk2 42 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
