Sorry to bring this thread back from the dead, but I have a question:
Can I wire these speakers in parallel so I can just run one set of wires back to the source? If so, how many can I run that way?
Depends on whether the amp will handle the load. Those are 8-ohm speakers, so they will present a 4-ohm load to the amp if you run two sets in parallel. Impedance calculator here:
http://www.bcae1.com/spkrmlti.htm
You can, of course, melt either your amp or your speaker's voice coils (don't remember which) if you do this trick on an amp that's not designed to handle it.
