That is slim! But those drives 'only' max out at 500GB. You'd be better off with one (or two!) WD20NPVT 2TB 15mm drives.
I know the builder has memory issues with drives over around 60GB or so, but say you built the partitions and filesystem manually on two 2TB drives, would a 4TB Empeg actually work? EXT2 can go up to 2TB, so that is promising. It would be space for over 1,000,000 tracks or so of typical MP3s. I wonder how big the player database can get before the Empeg stops having space for it? Would Emplode be able to add that amount of music in the first place? If it didn't barf, how long would adding that amount of music to the player actually take?
I feel like this is something that needs to be tried out.
