So, if you keep it and it never meets reg, are you going to be allowed to drive it?
Interesting question. If your car passes its yearly emissions test, is there any way they can detect if it was repaired or not?
More specifically:
- If you don't get it fixed, it passes the test because of the cheatcode.
- If you do get it fixed, then it passes the test honestly.
I don't know if there's a way for a local emissions-test station to be able to tell the difference. Is there something like a firmware version number that the OBDII connection reports? If so, they could probably check that.
