here is the log showing empeg sees it
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 ([email protected]) (gcc versi
on 2.95.2 19991024 (release)) #214 Sat Jun 23 16:38:57 BST 2001
empeg-car player (hardware revision 7, serial number 90000723)
Command line: mem=12m temp=31
Memory: 11008k/12M available (960k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-206000, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:d
3
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...t: old root has d_count=1
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
Tried to mount /proc but got error 16
No secondary hard disk
Starting player
empeg-car 1.01.
