The power connections are probably ok, along with the headlight dimming. If you car has nothing fitted into the hole on the car ISO that mates with the BLUE wire from the empeg, then you can just plug the empeg harness into the car.
You then will need to connect to the harness blue wire and feed this to your amp's remote input.
Hugo
