thanks again Tony, I will try and hunt one down. In the process of doing the led swap which is all done minus one led deciding to die on me, i have created another problem.. When the display was tested the image was very dim on the screen, i swapped the old display back into this unit and i was getting the following scrolling image for a bit before the screen just goes blank. So the issue is with the player main board but i dont know what to check. I have had done a search on here but didnt find anything concrete to check.
any ideas would be appreciated.!
https://www.dropbox.com/s/ca87bcaapjkm4hf/20180326_200850.jpg?dl=0
