empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v526 (
[email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue Sep 10 12:13:32 EDT 2019
Checking for extra DRAM:
c1000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 30102758) 16MB DRAM
Command line: mem=16m
Memory: 14992k/16M available (1000k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
show_message("Hijack v526 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xfe80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xfeff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hdb: IBM-EJSA-210! ! ! ! ! ! ! ! ! ! ! ! ! !, ATA DISK drive
hda: GUKIUSU MHM2101AU ! ! ! ! ! ! ! ! ! ! !, ATA DISK drive
hdb: HBL-DJRA,200, ATA DISK drive
hda: GUKIUSU MHM2101AU ! ! ! ! ! ! ! ! ! ! !, 8063MB w/2176kB Cache, CHS=16383/16/63
hdb: HBL-DJRA,200, 7937MB w/256kB Cache, CHS=16127/16/63
smc chip id/revision 0x3249
smc_init couldn't find card
Partition check:
hda: hda1 < hda5 > hda2 hda3 hda4
hdb: hdb1 < hdb5 > hdb2 hdb3 hdb4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...©«
¹„éYMéU¹
±Ń½µ½Õ¹Ńɽ½Ńͽ¹ĮĶéĮÕ)5’
