vwEMPEG writes: "as a TSD rallier I would suggest: 1 - time format to be in HH:MM.MM (division and addition of time is much eaiser when working with decimal minutes) 2- while GPS time or NTP time is accurate, it is not rallye time. you'll want to make an easy quick interface to modify the time. the rally master will display their clock for everyone to sync with. 3 - BIG numbers on the display.."
For the moment, I just want a better clock for more accurate "out times", so plain old seconds would be easiest. If I get something much more sophisticated, it may inadverdently launch me into Unlimited Class (The horror!). For the Friday evening TSDs I've done, the rallymaster just sets a WWV radio clock on the top of his car at sign up for time synch and I've also just used a little hand-held GPS to set time. I can only hope that the rallymaster is setting their clock accurately to that tone ('cause I never see it).
Agree. Big Numbers!
Jim (hoping to remain a novice for the maximum time allowed!)
Jim
