I did quite a bit of fiddling with it (I've an hour an the highway each way) this morning, with no change. Some of the buttons took a few presses to respond, but I didn't get anything working that wasn't working last night. I also put the heater on & aimed the vent at the stalk, but there was no change in behavior with temperature (it was about 35 degrees when I started the car this morning). I'm sure I'll goof with it more on the way home, but hopefully all will be well in 2.0.
-Zeke
Addendum: At lunch hour the Volume Up started to work, but still nothing that uses the inner rotary control. FWIW
just say you weren't paying much attention...
Edited by Ezekiel on 10/10/01 06:49 PM.
WWFSMD?
