As someone else mentioned it sounds like good vector map data is the biggest thing lacking at this point. Do you think it would be worth starting off with regular maps to get something going until a vector map data source can be found? If someone can get a simple moving map display working it could draw a lot more attention/help to the project.
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
