pgrzelak :
Thanks for all the info, I appreciate it! I would very much like it if you could email me that build that worked for you. I've sent you a private message and also a small email with my email adress. Thanks!
Tony,
I've tried re-downloading with getright. Didn't do much good though. Same error. So I guess that online file IS no good. Or at least no good with HD's > 30gig. (I've only tried it with my 48gig)
Bonzi,
Thanks so much for all that info! I'll wait for Paul to send me that file, and if that also fails I'll try what you're suggesting. It doesn't look too hard. Much like it would be in dos, except for the mounting part.
I will take you up on your advice however and let other check what you've wrote. Better safe than sorry, and I'm not in THAT big a hurry to get this going.
But what do you mean by "Sven's instructions are adequate (or, if you want to be on the safe side, mine up to first reboot)."
What do you mean by that? Does this mean I won't be able to use the 48gig as master and the 10gig as slave?
Thanks all!
Riocar 10gig (for now) S/N : 10101747 red
