For development for the empeg, you'll need a cross-compiler. The best place to find one is by following the links from smu's Web site, Programming the Empeg. I used Hulkster's pre-compiled toolchain and it all worked perfectly (on Debian 'woody', various i686 machines).
The next thing to do is to compile "Hello World" and see if it runs on the empeg - remember to use arm-linux-gcc -Wall. You'll need to install the minicom and rzsz packages to do the transfer - remember to make the filesystem read/write before attempting the transfer!
After that, the limit is your imagination...
Toby Speight - 040103385
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
