I know this is stupid (I did it) but check for IP address conflicts, especially if you network has some fixed IP addresses (usually printers - or empegs). Conversely, don't use a fixed address that's within a DHCP's scope for the same reason. I drove myself nuts with this, it'd work for a while then quit, not ping etc...
Also, when you switch to DHCP from the config screen of emplode, be sure to cycle the power to have the change take effect.
-Zeke
just say you weren't paying much attention...
WWFSMD?
