I should pretext this by saying I accepted any of the following issues when I downloaded the new beta. I wanted (and still want it) really really really bad. Lets hope the following is my fault some how.
I'm running Win2K, and I was installing the developer beta for the RioCar version. S/N 30102603. In the car I have a tuner and a Sony stalk.
1. I uninstalled the old empeg USB drivers.
2. I uninstalled emplode (1.0.3)
3. Installed the new emplode (2.0b3)
4. Installed the new developer kernel (2.0b3)
Installation all completed perfectly, no errors given at any point.
Immediately after the kernel install, the empeg reboots, flashy new startup guys!!! Then it puts up the static logo, gives me the initial loading stuff screen, then flashes to a screen with one horizontal line across the middle of the screen. It then immediately reboots and repeats.
Here's what I saw flashing by on the serial port ... If this is insufficient detail, I can give you more ...
Starting player
empeg-car 2.00-beta3 2001/10/17.
3bcda1f5 DHCP name = lo
3bcda1f5 DHCP index = 1
3bcda1f5 DHCP flags = 0x8
3bcda1f5 DHCP addr = 0.0.0.0
3bcda1f5 DHCP bcast = 0.0.0.0
3bcda1f5 DHCP mask = 0.0.0.0
3bcda1f5 DHCP name = eth0
3bcda1f5 DHCP index = 2
3bcda1f5 DHCP flags = 0x1043
3bcda1f5 DHCP addr = 192.168.0.6
3bcda1f5 DHCP bcast = 192.168.0.255
3bcda1f5 DHCP mask = 255.255.255.0
3bcda1f5 DHCP Adding interface eth0
Prolux 4 empeg car - 1.1090 Oct 17 2001
Vcb: 0x408ce000
E !! local_audio_player(275): memory violation at pc=0x020514bc, lr=0x020f6fc8 (
bad address=0x00000000, code 2)
componentpc : [<020514bc>] lr : [<020f6fc8>]
sp : be1ffcf0 ip : be1ffc98 fp : be1ffd08
.cpp 543: Invr10: 00000000 r9 : 022099c0 r8 : be1ffd34
alid tuner7 : 00000080 r6 : 022099c0 r5 : 00000000 r4 : 021ed4d0
informatr3 : 00000000 r2 : 00000000 r1 : 00000001 r0 : 021ed4dc
ion for FFlags: nzCvID 0x0. T IRQs on FIQs on Mode USER_32 Segment user
his is bad.
Control: C0EC517D Table: C0EC517D DAC: 00000015
@@ S0
Function entered at [<0205148c>] from [<02076358>]
r5 = 02224DB8 r4 = BE1FFD2C
Function entered at [<02076338>] from [<02075e10>]
r6 = 022099C0 r5 = 02224DB8 r4 = 02224CB8
Function entered at [<02075cdc>] from [<020ec52c>]
r10 = 020EC474 r8 = 0000300D r7 = 00000080 r6 = 0000000D
r5 = 022099C0 r4 = BE1FFD64
Function entered at [<020ec474>] from [<020f3808>]
r5 = 022099D8 r4 = BE1FFE40
Function entered at [<020f3740>] from [<0212e80c>]
r4 = 00000000
Function entered at [<0212cf80>] from [<020f3584>]
r8 = 0219712C r7 = 02197118 r6 = 020EC474 r5 = 00000003
r4 = 00000001
Function entered at [<020f34d4>] from [<0212e80c>]
r5 = 00000000 r4 = 00000000
Function entered at [<0219b3b0>] from [<020f5a28>]
Restored terminal settings
Abnormal player termination
Player received signal 11
Hope this helps!
Greg
RioCar (40Gig) Blue/Red/Green
'01 Audi A4 2.8 Quattro
