Most of the stuff in config.ini is available from the Player Configuration dialog.
For stuff that's not, add a "allow_edit_config" DWORD value to the "HKEY_CURRENT_USER\Software\SONICblue\emplode\2.0\Settings" key in the registry. Set it to 1. This will give you a config.ini option on the Tools menu.
Exercise extreme caution when editing it directly.
