I'm a bit confused. I've built the toolchain before with this thread, but this time the makefile script is failing. I remember having to modify more than just the PREFIX setting. I've had to remove the @ infront of the echo and exit commands. And it keeps complaining that it can't find PREFIX, or FILES, or wildcard, or FILES_PRESENT
./Makefile: line 8: PREFIX:=/home/oliver/armtools: No such file or directory
./Makefile: line 17: FILES: command not found
... etc
I also had to add a comment on some lines that the script was stopping on. If someone could take a look at this script, and make sure its mosltly functional, that would be great!
168178-Makefile (263 downloads)
Oliver mk1 30gb: 129 | mk2a 30gb: 040104126
