If you have made the changes to the config.ini for outputting FID information to the serial port, then you are seeing a known bug that is fixed in the next release. You remove that feature from config.ini to get your player working again.
If that's not the case, downgrade to 1.03 and see if that keeps you going until the next release.
___________
