Ok. What is apparently happening is my Pioneer remote still isn't working except for a couple of buttons that happen to have the same code that you compiled into the kernel.
I rebuilt the player and captured the output for each stage.
Followed Franks instructions again but the time I also added his enabling of the verbose ir output on the serial port.
This is the capture just after the IR only kernel was installed....
empeg-car v0.04 19990121 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux........................ done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg49 (mcomb@grovepc) (gcc version 2.95.2 19991024 (release)) #2 Sun Nov 11 17:27:32 PST 2001
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00102)
Command line: mem=8m
Memory: 7316k/8M available (584k code, 20k reserved, 268k data, 4k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
AD520B->B94615 11358731->12142101
AD520A->B94614 11358730->12142100
AD5242->B9460A 11358786->12142090
AD5243->B9460B 11358787->12142091
AD5212->B9461B 11358738->12142107
AD521A->B9461F 11358746->12142111
AD520C->B9460E 11358732->12142094
AD5240->B9460D 11358784->12142093
AD5241->B9460C 11358785->12142092
AD521E->B9465E 11358750->12142174
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0005900).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: IBM-DJSA-230, ATA DISK drive
hdc: IBM-DARA-218000, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
ide1 at 0x000-0x007,0x038 on irq 6
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdc: IBM-DARA-218000, 17297MB w/418kB Cache, CHS=37488/15/63
Partition check:
hdc: hdc1 < hdc5 hdc6 > hdc2 hdc3 hdc4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initI see this is a developer image!
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To CompStarting player
empeg-car 2.00-beta3 2001/10/17.
Prolux 4 empeg car - 1.860 Oct 17 2001
Vcb: 0x402be000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 2425870, error=0xc0044000
And this is the capture after I installed the map file and new init.
e000 v1.04
Copying kernel...
empeg state support initialised 0089/8893 (save to d0005980).
Partition check:
Mounting proc
Starting player
Vcb: 0x402be000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 829747, error=0xc0044000
E !! mp3_decoder.cpp 1047: Failed to find valid sync after seeking to offset 829747, error=0xc0044000
And this is what it is showing with the verbose reporting...
AD520A -> B94614
AD520A -> not sent
80AD520A -> 80B94614
AD520B -> B94615
AD520B -> not sent
80AD520B -> 80B94615
AD5210 -> AD5210
AD5210 -> AD5210
AD5210 -> AD5210
80AD5210 -> 80AD5210
AD5211 -> AD5211
AD5211 -> AD5211
AD5211 -> AD5211
80AD5211 -> 80AD5211
4 button presses.
Vol +
Vol -
Track +
Track -
The volume happens to be the same codes as my remote but the track buttons aren't.
Apparently it's not reading the ircodes file, maybe because there were already codes compiled in the kernel?
Any ideas?
Steve DarkStorm Designs
