Thanks ... The confirm box is actually already fixed. It will be in the next build.
Were you using JEmplode over Serial? What exactly happens when you try to connect via Serial after JEmplode? If you power cycle your Empeg can you connect Serial again?
For saving to a gif/jpg, I just need to track down an opensource Jpeg encoder -- should be pretty easy to do.
Mike
