I'd guess it was your supercap, not your car. If the time setting is lost when you pull the unit from the sled, the RTC is probably not getting juice from the cap. If you want, you can put a voltmeter across the capacitor's leads. If you get ~3V, it's good. Much less, and you should have the cap replaced
_~= Dearing =~_
Gettin' back into it thanks to slimrio!
