Greetings!
I assume that the FAT partition you mention is the boot partition for NT. The pagefile would be on NT's boot drive...
It has been a little while since I messed with NT4. Can you / have you tried the following?
a) boot with last previous good configuration - maybe a driver got whacked.
b) booted with logging to see what driver is causing the BSOD
c) performed a "repair" install of your NT, without replacing any files
Paul Grzelak
