I'm getting this issue also...The player boots into the car mode at 100%, then will dim down a notch when it get to the player. Switching headlights on will bring it back to full (I have both dimmer settings at 100%), and when I adjust the dimmer level, it jumps around, dim, bright, dim, bright as I'm adjusting the level, and when I get it back to 100%, somtimes I have to turn it another click higher for it to be really at 100%. I'm running 2.0b7 with the hijak kernel v92...
Also, when I boot with the AC adaptor, the display boots at 100% and stays there.
I'm going to try loading a stock 2.0b7 and drop it all the way down to 1.03 and report back in a bit.
--Ben
--Ben
78GB MkIIa, Dead tuner.
