Hi.
Don't know why the BBS showed this thread to be containing a new message, but anyway, it should do so as soon as I submit this one.
I really like the empeg case (have a blue one), I just wanted to note that I would really like the outside pocket to be just a little bit bigger (not more than 1/2 inch in width and length (along the seams that connect it to the empeg's compartment), no change in height. The pocket barely provides enough space for the cabling I would like to keep with my empeg: USB or ethernet cable, power supply, serial cable, audio cable plus the remote (that I usually keep in the same pocket as the empeg itself). And before anyone might ask:
Yes, I do need all these cables, because I didn't find a way to install a working telnetd on the empeg (so the serial cable is needed for console access) and I want to transfer (sometimes huge amounts of) data/music (so ethernet or USB is needed). The need for the power supply and the audio cable is obvious, I think.
cu,
sven
proud MkII owner (12GB blue now green, #080000113)
proud owner of MkII 40GB & MkIIa 60GB both lit by God and HiJacked by Lord
