The Emplode can't connect to the player database and the player seems to cycle through the bootup screen (which shows your name and contact information) and the "End of Playlist" screen.
This is a known bug in 2.0-beta3 (they really mean it when they say "beta").
If you downgrade to 1.03 (both Emplode and the player software), you should be all right until the next beta is released (which will have this bug fixed).
If, after you've played with 1.03 for a while, you decide you want to walk on the wild side again, you can go back up to 2.0b3 as long as you've got tunes on the player and an active playlist playing (the bug only happens when you boot to an empty playlist).
