Sounds exactly like an improperly shielded ignition system. The spark coils are computer in the car will adjust the idle in an attempt to warm up the car and it will cycle. The exact frequency that you hear depends on the idle rpm and number of cylinders (firing sequence). RFI leaking from the ignition system will appear on AM.
Calvin
