Okay, the following bug report has been filed:
"If you directly click on an item in the left-hand pane (for example, "playlists" or "all tracks" or "artists"), setting the actual focus to an item in the left-hand pane, then the Ctrl+F4 shortcut for closing the window does not work.
If you focus the right-hand pane by clicking anywhere in it, then Ctrl+F4 works again."
