I think I need to replace the knob on my empeg. The problem I'm having isn't the old "Loose Knob" problem, it's a completely different problem. (Although my unit does still have the old style knob, and I did run into the loose knob problem, and subsequently fixed it.)
The problem I'm having, is that when rotating the knob, one "Click" often results in 2 or sometimes even 3 position changes in the UI. I'm currently using 2.0b7, with Hijack v99. Been having the problem for the last few months or so, and it's getting worse. 2.0b7 has the "Rotary wear and tear patch" built in, right? Not sure what that's supposed to do anyway, or if it would fix my problem.
So, I guess my real question is, are there any replacement knobs available? Not just the plastic piece, but the whole electronics?
Dario
MK2 in an Impreza 2.5RS
