Also I never got an answer on if I need to load the developers build after disk builder or can I just go right for the consumer build
The only difference between developer and consumer builds is that the developer build gives you the ability to go to a Linux shell and have direct access to your filesystem.
If you are just planning on using your RioCar to play music then all you need is the consumer build.
