Is it an "Enhanced" CD? Check the packaging, or look on the outer edge of the cd for a ring that stands out on the surface. If so, the ripper program you are using might not be seeing this, and it will cause problems at the end of the first track.
I'm not familiar with your specific program, but when I had this problem in Audio Catalyst long ago, I could right click on the track and manually set it's end point.
