All the players were fully tested at the factory, with a ~2 hour burn-in and HDD test. The problem is the HDD cables which the factory switched to without getting our approval first - they may be glued on, but the crimping is bad in a much higher percentage of units than is acceptable.
Luckily, this is an easy fix for support to handle.
Hugo
