I have just installed a Rio Car player in my car and am absolutely thrilled, but have just a small problem. My car's interior lighting system has an intensity control and also works in combination with the amount of ambient light it senses. The result is that when my headlight's are on, the headlight sense will have different strengths/voltages depending on how much the car thinks it has to iluminate the dash. The Rio Car will definitely recognize this at high intensity dash-board ilumination. But at dusk, when the interior lighting is minimal, or when I set the intensity to be low regardless, the Rio Car will not detect that the headlights are on. There is a point where the Rio Car will be intermittent between the two dimmer settings, and this is particularly annoying because it gives the impression that there is a false contact. Ideally, I would like to tie the Rio's dimmer setting to the intensity of the car's headlight sense. However, I would settle for making the Rio's detection of voltage in the headlight sense input more intense. Is there perhaps a config.ini setting that would do this? I use software version 1.03. Any help would be appreciated. Thanks.
