Hi, I just recieved my unit, but when i plug it in nothing hapens, besides from the blue stand-by led flashing. - i connected it to my PC, when i ran the update util, it ran fine until after the harddisc preperation. Then it wrote "Bad pump response to device select" error occured during stage 0x20 - harddisc does'nt spin up, please help.
update:
when i disconnect the harddrive it sometimes gets further in the bootprocess:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected]) (gcc version 2.95.3 20010315 (release)) #8 Fri Feb 8 18:48:15 GMT 2002
empeg-car player (hardware revision 9, serial number 30102818)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Edited by beamer (08/02/2002 13:35)
- Regards from - Christian Byriel - Empeg MK2a
