The extra ID3v2 fields are not used or loaded into the player's database. When you view track details on the player, you are not viewing the tags, you are viewing the database. The tags are actually not used. The only time the tags get used is when you first drop the file onto emplode. Then it grabs the appropriate fields to fill out its database. It only uses the fields you see in the emplode screen, no others.
