In reply to:
But wouldn't it work just fine if the header said 'the track is a tenth of a second (or, say, 1 frame) longer than it actually is' ?
I wouldn't expect so - but then, I haven't actually tried it. Have you?
I think the track-length thing is a red herring, and that it's the presence of the VBR header that's causing the gap to appear. Some tracks without a VBR header appear shorter than they actually are (if they begin with a high-bitrate frame). Pink Floyd's "The Wall" tends to encode as a mix of longer and shorter than actual.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
