Looks like a wimpy lock that I could easily get through in a matter of minutes.
The price for that box ($106) is pretty steep as well. Might as well use a Pelican case bolted to the floor of your trunk. Then use some quality locks on the case.
As a followup to whomever suggested using some type of cable lock in behind the empeg when it's installed in the dash. STUPID idea. Not just a "bad" idea, but a STUPID idea. The primary impact of security is on a visible level. It works best as a deterrent. If you hide the security, someone will still break into the vehicle. And when the pull the deck out to find it's tethered, they're going to be pretty pissed off. They'll probably smash the deck and completely trash the inside of your car. Most modern cars can completely be written off if the interior is very badly trashed.
The best approach is a stealth one. Take the empeg out and put it somewhere else. If you lock it in a plain ans secure box in the trunk, no one will know exactly what is missing from your dash. They won't know if it's worth breaking into your trunk and will likely just pass by onto an easier mark.
