Duh, just re-read tonys post come up with the following cunning plan (Blackadder anyone?)
If you can connect to the player using emplode via serial, then this will prove out the cable and COM port, start looking at your hyperterminal settings.
If you can't connect using emplode then the problem lies in you cable or something grabbing the COM port.
