I don't think that the voltage variation will make much difference to your cooling fan. Why not use the amplifier sense wiring? The fan will draw a minimum amount of current and will come on only while the unit is turned on. If your concerned about excessive current on the sense wire then use an interposing relay.
Edited by Neutrino (19/02/2002 09:54)
No matter where you might be, there you are.
