Is there a way I can check the size of the config.ini or otherwise check it out without deleting it first?
Yes.
You have to be set up to be able to edit the config.ini file through emplode. If you are not set up to do this, you need to look
here in the RioCar FAQ to see how to set that up.
Then, all you have to do is go into emplode/tools/edit config.ini, it will pop it up on the screen and you can look at it, edit it, do whatever you like. I recommend copying it to your clipboard and then saving it as a text file somewhere just to have a known-good backup copy.
If your config.ini is suffering from the "corrupted first line" problem, I think your emplode config.ini editor won't work, and you'll have to delete the config.ini file.
