Okay.... here we go. It actually went about 3 hours and 15 minutes this time before this happened. I powered up the player and put it in standby mode, established a hyperterminal session, and then cycled power to the player and let it sit until it did a reboot.
Everything up to the "Vcb: 0x4054d000" was the regular startup sequence after the power was cycled. The "Vcb: 0x4054d000" was the last thing sent from the player after going into standby. About 3 hours and 15 minutes later, I got the error messages - I wasn't around to see it, but my guess was that the player had rebooted (or at least tried) at that time. When I came back and found this reported error, the player would not come out of the standby state.... which is a first.... it usually behaves seemingly normal after one of these self-induced restarts. I had to power cycle it to get it responsive to the front panel buttons again.
Notes: I am using 2.0-b11, a custom logo, and have flashed the v200.hijack.v200b11.mk2 hijack image.
Thanks.....
empeg-car bootstrap v1.00 20000601 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v200 (
[email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue Feb 12 22:45:07 EST 2002
empeg-car player (hardware revision 7, serial number 90001020)
Command line: mem=12m
Memory: 10920k/12M available (1000k code, 20k reserved, 344k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004480).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:fc
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
Mounting proc
Starting player
hijack: removed menu entry: 'Home/Work Location'
hijack: removed menu entry: 'Hard Disk Detection'
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4054d000
no room for private writable mapping
error: -12
error: -12
out of memory
Restored terminal settings
Player exited normally: 1
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin#
