Okay, I finally relented and implemented a workaround for the messed up INFO modes in v2.00-beta-11 of the player software.
Hijack v216 has a menu item to enable/disable Restore Visuals (v2beta11) which, when enabled, fixes the INFO mode on reboots in AC/Home mode. If you use this, ensure that your initial= button press sequences in config.ini do not conflict with this mechanism! Also note that this is for use only with the beta11 player software, so turn it off if you are running anything other than beta11.
Note that the pre-existing Restore DC/Car Visuals already handles the DC/Car case (it was broken until v215, but works again now).
Also new in v216: increased max number of dance= lines from 10 to 16, and added error-recovery for missing dance files (like, after a player upgrade.. doh!).
Enjoy!
