I received my 60 GB Rio Car (blue) yesterday and get nothing but logo screen and it's really frustrating. Tried upgrading S/W and now i get "No hard disk found Contact Support" with a Penguin which made my day! :-) I am fairly competent computer and hardware wise but not willing to open unit for Warranty sake yet.I have e-mailed support and waiting to hear back but I'm getting ICE installed on Tuesday so looking for quick fix.
Hyperterminal gives me the following but means little to me:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v225 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Sat Mar 2 09:22:29 EST 2002
empeg-car player (hardware revision 9, seri
Command line: mem=16m
Memory: 14968k/16M available (1008k code, 20k reserved, 384k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 16384 bha
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)096K size18
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )nnel IDE
06f0 ethernet ok
hda: fUjItSu mHl2300At, ATA DISK drive231 rev a0Wed May 2
Starting kswapd v 1.5
SA1100 serial driver version 4.27 with no serial options enabled driveok
00f0 tests comp
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART on irq 6rap v1.02 20001106 (hugo@empe
hda: fUjItSu mHl2300At, 8063MB w/6144kB Cac
Uncompressi
Signature is 206f6972 'rio '
empeg display initialised., 8063MB w/6144kB Cache, C
empeg dsp audio initialised
empeg state support initialised 0089/88c1 (save to d0004700).
RAMDISK: ext2 filesystem found
empeg RDS driver initialisedon 1112 id 1012
RAMDISK: Loading 320 blocks [1 di
hdb: fUjItSu mHl2300At, ATA DISK drive
hda: fUjItSu mHl2300At, 8063MB w/6144kB Cache, CHS=16383/16/63
hdb: fUjItSu mHl2300At, 8063MB w/6144kB Cache, CHS=16383/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:5
6
Partition check:
hda: hda1 < > hda2 hda3 hda4
hdb: hdb1 < > hdb2 hdb3 hdb4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
ALSO, ctrl-T gives the following if it helps:
empeg-car bootstrap v1.02 20001106 ([email protected])revision 11
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id fUjItSu mHl2300At
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 00
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
Should temp=00??
Regards
Scoopz ([email protected]) for MSN messenger
FOR SALE (UK):
Rio Car 60GB blue
serial : 030102646
